Heya peeps, I'm having a mare trying to find the torque setting for the Injector Bolt/Nut on these things.
I forget the technical term for it, but there is a claw/ pinch part that effectively tightens down on the Injector holding it in place with enough force to squish the sealing washer etc.
I initially tightened to full on white knuckle hand tight with new washer but on first start up is leaking so I'm sure it needs more torque/ nipping up etc.
I've found what I'm talking about on google, but specifically in relation to mercedes model. That advises that its bolt should be tightened to a torque of 7nm initially and then a further x2 quarter turns, do you think these would be similar with additional turns etc?
Chrz
Chrz
