I have a friends 2.8jtd and it will not start also he had a problem with it last yr and the cam belt had sheared 2 teeth from it it would turn over but not start got it running new timing belt fitted and crank sensor as it had a knock from belt I presume. Been running ok for the past 4months. Any way he was going out in it last month and it just stopped at a roundabout. And will not start we haven’t looked at it yet NO TIME. It cranks and immobiliser light extinguishes. But will not fire up. Any ideas please. I thought it might be the fuel rail pressure valve or pump but as I say not looked at it yet regards. Paul. (Elmer )
I also have a 2001 ducato 2.8 jtd with injector light intermittently appearing and loss of power. I’m putting that down to 2 things that I have come across on the forum 1 injector connections too tight which I have moved the clamping at right hand side to give a little slack. 2 throttle position sensor it has had a new one fitted by a commercial van place (Mercedes dealer ) ?? Before I purchased the vehicle but still this problem seem to exist so i think it could be the wires going from pedal to connector intermediate connector to ECU not check yet need to put my multi meter on them I read that there have been problems with this part of the loom and people have bypassed this connector and soldered new wire to the ecu connector. So I may go that route if I find high resistance on any. Thanks.
- Model
- Ducati maxi 2.8jtd 230
- Year
- 2001
- Mileage
- 75000
