Technical 20 V Turbo Air con
icom102
Hi I have a 20V Turbo when I hit the Aircon button the light wont come on and also no cold air would anyone have any idea what the issue could be ?
Ok had a nosy when the car is on and fan at 0 if I hit the ac button the fan comes on so it must it must be doing something
Do you actually get any cold air out the vents?
It may just be a bulb burned out behind the button.
If the fan comes on when activated that does imply the system is switching on, and is fairly easy to check on the 20v turbo as the compressor is on the front at the top of the engine bay. Just turn it on and see if the centre of the compressor is turning with the pulley.
If it is but the aircon is still not cold then all indications point to it being low on gas
im getting colder but just like you would from a car with no ac I will have a look at the pump and see
Ok checked it the centre of the pulley is not turning no matter what setting I use
I'm sourcing fiat couple 2.0V blower module parts no:501300080034/576540600 MCC55F SW 1.7 5586 09/04/99
Version:175AXD1B 04B
Any body can supply !
Thank you
