Technical 2.8 fiat Ducato gearbox
Jon25081258
Bridgend
Hi I have a broken gearbox on my 2001 fiat Ducato Motorhome it’s cracked the box unfortunately I am trying to find out where to get a replacement and struggling it’s the 2.8 non turbo and have been told by fiat original box was part number 9567357680 I would really appreciate any help at all as garage asked me to supply gearbox for them to fit thank you in advance
Model
Ducato swift 2.8 non turbo
2001
Mileage
100000
Suggest you try wikipedia to see what other makes are "badge engineered " similar models, Peugeot Boxer, Citroen Relay, it may widen your search?
Often scrapyards will know if there is a match, so it may be worth trying them.:)
Thank you for the help I have tried a few scrap yards but no luck as yet but appreciate any help 👍
Hi folks my wife and I own a Autotrail Arapaho MH we had problems with four adults sitting in the front, when travelling we turn left or right the wheel arch would cut the tyres, so some thing had to be done, I found Travel world in Telford sold heavy duty springs, these lifted the front of the MH three in higher, no more shredded tyres
I have recently fitted a new alternator and that was very taxing, when lying on your back and dark all you can do is feel that every thing is going right Kind Regards Eric,
Good evening I have a problem with my gear box
it is a Ducato 2.8 JTD 5 speed manuel, i have replaced 2-3 syncros but when i come to reassemble the gears jam,
can any one tell me what i am doing wrong
Thank you Eric
Thank you Eric
I am guessing since it is sometime since I rebuilt any gearboxes, but generally there is a series of ball bearings and springs in the casing with a metal slug in the same tubes , the purpose of which is to prevent two gears engaging at the same time which obviously jams things.
It is usually where the selector rods slide back and forth.
