Hi Just joined to see if I can get any help with a problem on my truck.
2007/8 Ducato 2.3 multijet 130bhp It has decided not to start but maybe will sometimes, all warning lights key locked symbols go out as they should when turning on the ignition, turns over fine but will not start, it appears as if the fuel cut off is not reactivating, checked fuses and relay for fuel pump all ok. checked wiring to fuel Hp pump no power at the plug same as camshaft plug no power there.
Can anyone tell me if the big relay on the wheel arch has anything to do with the fuel system?? This is held in with a big blue clip truck has started after unplugging this relay or has anyone a description of the various relays on the van as it seems to me that a one is sticking needing replaced, hoping its not the ECU.
The truck runs great when it goes and may start many times ok but then will not start for many times!!!!!
Regards in advance Mike
