I have a Ulysse 2.0 JTD S 02 reg. I’ve searched the forum and hope someone can help. I have lack of power on hills in fact down to 3rd gear on a slight incline if there is a head wind. Goes like a rocket round town especially from cold. I have tried every angle I can find in the forum so far. Over
4000 RPMs you can here the injectors kick in and there is a big trail of BLACK smoke. Wastegate actuator on turbo is working if I suck on the pipe from the turbo to the solenoid at the solnoid end (centre solenoid above radiator between EGR and Throttle solonoid) you can here it click shut on release of vacuum. Changed MAF Sensor. Checked all the pipes and got a fault code readout which states “Wastegate Solonoid Fault”. Had all the faults cleared and fitted new solenoid and still the same fault came back. The guy at the garage now said it can only be an ECU fault or the connections to the ECU from the Wastegate solenoid. I’m at the end of my tether now. Does any one please have any input other than what I’ve already read and tried? If I need another ECU can I just get a second hand one from a breaker or will I need to get it programmed in. I’d be greatful for any help thank you. Terrylee
