Hi Everyone!! I've bought a M reg 1.4 Tipo i.e off this very forum a few months ago to use for my daily commute to work.
However when it's running at full temperature it'll idle normally one minute, then all of sudden run at a faster idle of it's own accord?
It does go away back to a normal idle, but I really have to rev it to make it go away which I don't want to do so I've stopped driving it.
I changed the stepper motor for a brand new Bosch item, which did make the car run more smoothly than it did before.
But the problem still occurs? I'm thinking it could be the Digiplex as that has a vacuum pipe and a plug going to it.
Unfortunately money is tight, and I can't afford to pay a garage and don't want to start buying loads of bits that it doesn't need.
Any idea's if the Digiplex is a common fault, or should I be looking elsewhere?
Your comments or advice would be much appreciated
Cheers,
Paul
Cheers,
Paul
