SDHXIII
Hello everyone.
After a bit of advice and opinion please.
I have a 1969 500 F with a 126 650cc engine. I have had it for a while now and it has never really run that well. The long and short of it is I have tried many things over the years including have a Powerspark ignition system installed.
Despite this it still isn't great. When running it seems to pop intermittently. I have recently added silicone HT leads as recommended on this forum as the garage that installed the Powerspark system put the old leads back on. I have also replaced the spark plugs.
Tonight when I started the thing up it was still poppy and lumpy and I noticed that it was sparking or firing at the base of the carb as it popped. I have put a video on YouTubes and you can clearly see the sparking
The question is; what could causing such a thing and what could a remedy be. I'm a bit worried, given the location of the sparking that the whole thing could go up in flames
HELP!!!!!!
Thank you.
Stuart....
HELP!!!!!!
Thank you.
Stuart....
