hello all! I have a 1967 fiat 500 I’m going through to revamp the electrical as it would start. I’ve replaced the coil, distributor arm, plugs and wires, etc. It still wouldn’t start unless there was fluid being injected into carburetor. I replaced the fuel pump and fuel line which solved delivery but still won’t start. I jumped direct power to coil, and it did start and ran which points me more toward the Infiniti on switch.. Upon inspection it appears one line is loose but my manua really does indicate which connection is what. Two questions:
1) can anyone provide a diagram with which color wire goes to which connector?
2) May not be the right fox but at least temporary , is there any issue with connecting a new switch with direct power from dues to coil? Not sure if there’s any kind of a limiter in between the switch and coil that would reduce amps/current. Don’t want to blow anything out… would at least let me to start and move it as I rehab everything.
Open to suggestions. Also, looks like I should replace / upgrade the fuse line/box too. Still has the old fuses but looking for quick fix for now.
