Replaced fuel line filter as originally running lean. Now uses petrol like there is no tomorrow! Tried replacing air filter, also replaced temperature sensor for injection system (the one with blue cap 2 leads near inlet manifold). Also replaced the temp sensor on block (this supplied incorrect as temp warning light glows in relation to temp when should be simple on/ off switch) -dont think this is the problem though. Otherwise goes very well performance great. Just ++++ fuel consumption...
Should i look at the ECU or is possible to reduce fuel line pressure??
