Technical 110D Oil Filter Housing Removal
IanEmery
Established member
Oulton Broad, Suffolk, UK
I know these covers are very fragile so I’m asking for tips on removal. I’ve got clear access with the rear bumper panel removed but, on inspection, I’m worried about the corrosion there is on the steel that this alloy part bolts up too. I’ve given the joint a really good soaking with graphite penetrating fluid overnight and will give it another good soaking tonight but I’m wondering what I should do next to release the cover, hopefully tomorrow. :bang: :bang: Comments from my forum mates would be appreciated.
Ian, If the filter will not come off readily Tap it 'lightly' with a rubber hammer in the middle to shock the joint this should work unless the corrosion is bad and you may need to be more firm - watch out for the oil loss too.
Ian.
just smash the bejeebers out of it..
I'm sure I can sell you one for £250 :)
or... it's just time patience and lots of tapping with a rubber mallet is what I did.....
but Sean and Andy may be along with their experience of removal from ultra rusty cars
Ian.
Thanks Ian. Hopefully the fluid will have got into the joint and it won’t take too much hitting when I try tomorrow.
I don't know if the earlier engines had this useful tab that I have on my engine, but here featured in the same arrangement on my 900e van.
MAL_0146 by Peter Thompson, on Flickr
Thank you Peter. The tab shown on your photo shows that Fiat gave thought to this but unfortunately on the engines prior to the change from D to F models the belt pulley is integral to the cover and it fits over the main steel body which contains the oil slinger so there isn’t any convenient point to lever against.
Now Peter why didn’t I think of that :doh: just send you some money for a new one! So easy :nono::nono: No, I think I’ll go with treating it gently taking your second suggestion (y) :D Thanks
:bang: Prototypes! :):D:D
Hi Ian,
Can you post a before picture?
(Before you break it, I mean :devil: )
AL. :D
Hi Ian,
Can you post a before picture? (Before you break it, I mean :devil: )
AL. :D
and an after :)
you will see many broken ones with a piece of the pulley missing, it seems to be that as there are little slots in the alloy the usual approach is to try to use a screwdriver wedged in the outer edge of the pulley to lever the cover off...
Here's one someone did earlier... (and it wasn't me!)
ohhh can you imagined that polished up
How about tapping threads into a couple bolt holes opposite each other. Screw a couple of bolts into the cover and pull on the bolts using self locking pliers? Or do the above and use slide hammer gently on bolt/s?
ohhh can you imagined that polished up? I can....
Joe R
but it would be the size of a house and involve removing the engine and mounting it on a special frame..
Should this become a “Forum Approved Workshop Tool” or just stay as a very useful, non-damaging, tool? :D (y)
Very little crud on the filter plate and no evidence of metal particles so I’m a happy ? boy! :D :D
A good idea but, as it happens, the cover came off fairly easily for me. I don’t know if it was the graphite release fluid that did the job or what but now it’s off I really don’t know why I was so worried ? :eek:
