russwatkins
- Joined
- Dec 27, 2014
- Messages
- 14
- Points
- 5
I swapped the cambelt on my wifes GP Sporting 1.9JTD a few weeks ago. Bolted everything up and it started first time - no issues whatsoever.
Swapped the Fuel filter whilst I was at it as well. After a few days the wife mentioned a smell of diesel when driving. Sure enough, the fuel filter was leaking quite a bit from the sensor. Tightened it up and all was good.
The next day she mentioned that it was difficult to start. It goes nearly perfectly from cold. Take it for a run and the car pulls perfectly, if not better than ever! Once you stop the car however if you go back to it 10 minutes or later afterwards, it will not start or takes about 5 minutes to get going.
I have checked that I plugged everything back in, then plugged a code reader in - nothing. I was sure it was the crankshaft sensor however I have just finished swapping this and it hasn't made a difference. I am now at a loss.
The car still drives perfectly when you get it going. The only other thing I did was that I put the old fuel filter back on for a short while to make sure that the filter wasn't the issue.
Anyone any ideas?
Anyone any ideas?
