Eastendborn
Hi there, Eastendborn here- Fiat Doblo owner. Can anyone help with my cutting out problem please?
Hi there, Eastendborn here- Fiat Doblo owner. Can anyone help with my cutting out problem please?![]()
Suspect crank sensor.
Hi, thanks for replying- no lights to speak of- glow plug light goes out after a few minutes -fuel filter changed a week agohi, and welcome,
need more info really,
any fault lights / messages lately,
glowplug circuit o.k. ..,
when was the vehicle last serviced,
fuel filter..??
reading stored fault codes is a good start.. but may not be anything if you've not seen a warning light,
Charlie - Oxford
I haven't changed that- I will see if I can get one and change it- thanks.Its a possibilty..
but could be almost anything..
Thanks all for your help. Once again Autumn is here- along with it the colder weather. My 1.9 Doblo has been good all summer (as it was the previous summer) but now it is back to it's usual cutting out trick. Nobody can seem to solve it. For some reason or another it usually happens when soon after starting- I put it in reverse. Straight away it cuts outs. If I go forwards it doesn't happen so much. I can go on a long journey and it is ok. Then - even when the engine is warm - it will cut out upon pull away - or just putting it in reverse. Sometimes it cuts out when I'm going along- and it is scary because I lose power steering.
Worth having a look at the earth cable as well. The black negative lead from the battery and is bolted onto one of the gearbox fixings. They can corrod internally at the bottom connection. A cheap fix if you get your local auto electricians to make you up a spare negative cable and bolt that new one on as well. Have been it posted where peeps have attached a negative jump lead on as a temporary measure to eliminate of prove a poor earth situation.
p.s John- do you know where the throttle position sensor is located?
Thanks John, and Charlie - appreciate you guys I came back from coast today, 40 mile trip - car went fine then cut out when I went to start it after having stopped for 2 minutes. Thanks again blokes![]()
:yeahthat:A jump lead added at times of non starting could make all the difference.
