Technical 1.8 gearbox drain and fill plugs location
Ante
I've changed oil on quite a few different Fiat boxes over time but it's always a bit tricky to figure out which plugs are the correct ones. There's usually 3-4 of them in that general area of the gearbox. Can somebody post a picture of where they are located on the 1.8 version or is it very obvious (which is usually isn't according to my experience)? ;)
I assuemd the gearbox plugs would be somewhere on the gearbox :confused:
Oil is changed now. Plugs were placed as usual on Fiat boxes. Drain on the side of the box, close to the bottom, 12 mm hex. Fill is about 3-4" up from the bottom, on the front of the box. I hope this helps somebody in the futurte planning to change the gearbox oil on the 1,8. ;)
