thespark2001
- Joined
- Nov 2, 2008
- Messages
- 14
- Points
- 1
Hi there,
Sorry I have been mis-informing you cylinder 3 is not missing its not firing, using a auto range meter with a range bar on idle and at D81 connector on volts connected to positive the range bar bounces on cylinder 1-2-4 so conclusion is that there is no voltage pulse on cylinder 3 the cable has been checked from ECU to plug and tested OK, could be the ECU or another sensor going mad?
Any thoughts?
Thanks.
Any thoughts?
Thanks.
