Today I back probed the map sensor wire with the digital multi meter. I am getting 4.98V on a 5V reference. The map output is 4.47V when the key in 'Mar' position. As the engine idles the voltage is 1.57V @ 800 rpm and 3k rpm its 1V.
Now the issue is when I switch on the AC button the output at idle changes to 1.96V and 3K rpm around 1.35V .I also checked the reference voltage with A/C there is no change still shows 4.98V. This eliminates Linear pressure switch issue. Now I am struck :bang: what causes the raise in MAP sensor voltage to 0.35V . Is this normal ? It will definitely affects the mileage. Please help.
Regards,
Vijay
Regards,
Vijay
