worcestersource
Whether it was the ice last week or the fan had failed in some other way, my car boiled over in stop-start traffic last week. Unfortunately, I couldn't just stop in the rush hour traffic but was able to kill the engine and coast into a side road as it boiled over. By the time I'd found coolant to top it up, the traffic had eased and I got to work (the fan only ever kicked in when the car was stationary and never when moving). I got towed home rather than risk driving without a fan. Both my own checks and those of the RAC confirmed the fan had blown out. The car was very happy to start and move around in the car park at work, so had been able to cool down and start again.
So, fitted a new fan today and replaced the fuse. The car started up but when I closed the bonnet, it cut out! It wouldn't then restart.
I thought I'd check the usual... spark, petrol etc. I have some nifty spark lights that you pop on between the spark plug and ht lead. Although no.3 (going left to right) appeared to be getting a spark, none of the other leads did. I tested 3 again and no light, so I checked battery and well under 12v but this could be because I'd drained it through all the cranking I'd tried.
After recharging the battery for most of the day, it ran for about three seconds and then died. It won't start again.
Given it's dark now, I've not run any other tests. Tomorrow morning, I'll test and charge the battery again as it might need a new one. The engine turns over just fine, so I doubt it's the starter nor earths.
Are there any quick gotchas on the 1.4? Could dropping the bonnet cause something to pop out or come loose? I know my way around a carbureted Rover V8 but this is new territory for me. Never seen so many computers! How do I test for petrol feed?
Thanks,
Steve
Thanks,
Steve
