Technical 1.4 Fire engine electronic throttle problem
alfamaniacs
Hi Guys, Andrew in South Africa here.
I have a Strada Pick-Up (Palio utility) fitted with a 1.4 8v FIRE engine with electronic Marelli throttle (44SMF8)
Was running great until one evening i got in, started and the EML light came on and the accelerator pedal failed to respond.
I fiddled around and discovered that it also chuffed on idle running rich and occasionally the cooling fan would come on.
I suspected bad earth so i cleaned all the earths and battery connections - no luck.
I was fortunate to have have stripped another vehicle for spares a few months prior to this so i had plenty spares - this is what i tried.
Swopped the following:
1) ecu/key immo module
2) throttle body
3) engine wiring loom
4) accelerator pedal
5) MAP sensor
same problem
Diagnostics (AlfaOBD) shows
codes: P1121, P1122
Live data shows the accelerator pedal is incrementing when pressed.
Throttle body is stone dead - no clicks or buzzing - any attempt to reset it with diagnostic tool results in failure.
Pressing the butterfly with my fingers whilst viewing live data shows that the throttle position sensor is working.
I have checked all the connections but I am in need of the pinouts for the throttle body and ecu (IAW 4SF)
I dont have a PWM tester so I can power up the throttle bodies independantly to test them so I am at a loss
The only other thing is that is mentionable is that the air conditioning compressor fuse popped at the same time
ANY help or advice would be greatly appreciated
Regards
Ive established that there is no output pwm from ecu to the throttle motor
The throttle potentiometers are both reading
Solved - ecu blown
Not to sure if it was the a/c circuit or the throttle body driver that was the culprit but it took out both ecu's
