Technical 1.4 cruise control wiring diagram
StiloCZ
Hi, I am searching for the wiring diagram from the engine node to the cruise control stick on a 1.4 but can't seem to find it anywhere.
My 2005 Stilo does not have the cable by the stalks under the steering wheel and is also missing the brown connector by the battery. (I've searched everywhere).
The guide on the forum does well in explaining everything and contains wiring diagrams for all BUT the 1.4 engine. Any help please guys? Here's a link to the guide for reference.
https://www.fiatforum.com/stilo-guides/55049-cruise-control-installation-gars7.html
Thanks,
You need to connect wires direct to ecu because you have post 2004 Stilo and Fiat removed that cable if you didn't buy car with cruise control. Long time ago i have 2006 Stilo and I need to do that. Stilo before 2004 has all that cables.
Yes I know thank you :) that's why I'm searching for the wiring diagram for the 1.4 [emoji106]
You can try this. I hope that is correct because it is for 1.4 16v
So the 1.2 and 1.4 have the same wiring diagram for connecting the Cruise control to the ECU. Can anyone confirm?
