I have a query regarding the drivers side engine mounting in the pic attached. This is a bit hard to describe so please bear with me.
In the centre of the mount where the arrow is pointing, should there be any play where the engine side enters into the centre of the rubber block? The engine side is resting on rubber, but there doesn't seem to be anything holding it in place. I can fit my little finger into the centre of the rubber above the engine side. That side of the car feels a bit "shunty" when you apply power abruptly and then lift off. I don't want to go to the hassle and expense of swapping bits that might be ok
Advice would be appreciated....
