so are there anybetter one that fit onIt sharpens up the engine nicely: there really don't seem to be any pitfalls apart from the need to check the valve clearances and probably re-shim the valves.
It's by no means a wild cam.
does the 75cam give you more power like does it chang the 0to60 and topspeedi relly dont no anythink about cars sorry
Generally, lumpier cams will produce more power, at the expense of producing it higher up the rev band and with a narrower power band (peak torque and peak power closer together), so, more gearchanges, and much harder to drive.
so does the 75cam put up your bhp and only wonted to no about topspeed and 0to60 becouse sometime this year i am goingto be geting a fiat500 and then the cinq well be my track carAnd much more fun, and you always get out the car with a smile
If we accept that Punto 60 engine (1242) puts out 60bhp and a Punto 75 (1242) engine puts out 75, then, the differences are basically that the 75 is MPI and has a better cam.
what type of track? the cinq is a great car for auto testing (light weight, small, front wheel drive) or sprinting. basicly good for twisty tracks imothe cinq well be my track car
anytrack im just going to keep it so i have a car for trackdaywhat type of track? the cinq is a great car for auto testing (light weight, small, front wheel drive) or sprinting. basicly good for twisty tracks imo
if your using it for just track you could get a very spicey cam made up for it for a couple of hundred. perfect for a track where you will be able to keep it where it makes the power. :slayer:anytrack im just going to keep it so i have a car for trackday
