Right here goes....!
I lost reverse gear around a month ago, I finally got round to taking the gearbox out 2 days ago. I knew what the problem was it was a piece of metal stuck in the end of the reverse gear tube that the selector forks are on. I had the same problem on my 07 Citroen relay so thats why I knew what the problem was.
Me and my dad put the gearbox back in and put it all back together, while up in the air I started it up in first gear to see if it was working which it was, wheels were spinning. I then tried reverse and everything was fine. I turned it off then we bled the clutch which seemed like a right struggle.
Started van up went to take it for a test drive and i've got no drive in any gear. Clutch goes down and goes into gear but nothing happens when I lift my foot up. If I put it in any other gear other than 1st and reverse i'm getting a griding noise.
Can anyone shed any light on what the problem could be? I'm thinking it could be clutch but there was nothing wrong with it before we took it out. I don't think we damaged anything while doing it either.
Sorry it's a bit long.
