General 07 160 multijet side lights and dipped
kennyo0
Hi couple of questions regarding my lights on a swift mh.
Problem one. I have no side lights after I removed one and the wires touched (cable had been stabled to floor inside so no loose when removing) how do I get them back on have read that they use a can bus and not a fuse is this correct and what can I do.
Problem 2.The passenger side dipped and rear lights come on then go of and stay of. I had the van in the garage before we came away as the warning light was on and they told me it was sorted as the warning light was not on never thought much of it. Driving through Germany noticed rear side light was not working so when I checked it the bulb had been removed, replaced bulb and checked lights that is when I noticed lights come on then go of. The drivers side works fine it is just the passengers side and the two rear side lights must be in the same circuit as the rear lights not the side lights, removed bulb and the lights started to work for a bit then went out
anyone any ideas
