General  Coolant tray 2007 160 multijet
Keith1950
South wales
Hi
The tray that Suports the coolant header tank just behind the headlamp is starting to corrode, is this a replacement part or do I have to fabricate a new one thanks .
Keith
I had to replace both on my 2008 , O/S & N/S but found neither were available from that supplier.
In the end I located a pair from a breakers via the Gumtree.
At the time I couldn’t find any supports listed but an email or several to sellers breaking Ducato’s, Boxers & Relays got me a pair.
Thanks 😊
I remember the days when one was allowed to go around scrap yards and remove parts yourself , and take an empty toolbox in and a full one out
I fondly remember scrap yard forays - sadly the Elf n Safety crept in and curtailed such behaviours.
Heading back to your quest, bearing in mind they were the same bracket from 2007 to 2020; Here is one I found during a quick search on the bay of E.
What condition is the fuse box/ecu bracket on the n/s in? If there’s any corrosion I’d change that too as it forms part of the overall earth path from earth lead to jumpstart connection on the slam panel.
Thanks for the link , I haven't checked the other side but that's worth knowing
Regards
Keith
