G ghinzani New member Joined May 16, 2017 Messages 3 Points 1 May 18, 2017 #1 Hi, first post. Can anyone point me in the direction of a 13" wheel, Fiat or otherwise that will fit an 03 Doblo van to replace the 14s on it? Many thanks
LeadMagnet Member Joined Aug 9, 2016 Messages 70 Points 96 May 25, 2017 #3 I'm not sure if a 13" rim would fit without the front brake calipers or rear drums rubbing the inside of the wheel. Your best bet is to find a custom wheel shop in your area and have them measure what will fit, very precisely. Not sure why you want to go down in diameter as this will change everything about the vehicle (handling, speed, fuel economy, etc) Most of the time you want to go up, getting a lower profile tyre to improve performance. M2CW
OP OP G ghinzani New member Joined May 16, 2017 Messages 3 Points 1 May 26, 2017 #4 Cheers for the info, I hadn't considered the brakes. I have a steady supply of performance 13" tyres basically.
