H Humph Member Joined Oct 23, 2014 Messages 26 Points 60 Jun 28, 2016 #1 Hi Guys What are the valve clearances on the 8 valve engine ? Humph
T Twitch525 New member Joined Jun 21, 2016 Messages 56 Points 13 Jul 1, 2016 #2 Inlet 0.40 Exhaust 0.45
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,187 Jul 1, 2016 #3 Twitch525 said: Inlet 0.40 Exhaust 0.45 Click to expand... Thats not the spec iirc Its got a range in it Exhaust is always higher due to the heat When i get chance - i'll get the haynes out and look Ziggy
F flisko ` Parked in the garage Written 5 guides Joined Jan 20, 2013 Messages 6,122 Points 1,228 Jul 1, 2016 #4 is there a point in adjusting valve clearance?
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,187 Jul 2, 2016 #5 flisko said: is there a point in adjusting valve clearance? Click to expand... Only if valves have been reground in and tollerance is now too tight ziggy
Brendan W Patron member Joined Nov 23, 2005 Messages 3,038 Points 669 Location Wexford Jul 2, 2016 #6 Valve clearances are In 0.40 +/- 0.05 mm Ex 0.45 +/- 0.05 mm Ours were still in range at 100 000 miles.
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,187 Jul 3, 2016 #7 Brendan W said: Valve clearances are In 0.40 +/- 0.05 mm Ex 0.45 +/- 0.05 mm Ours were still in range at 100 000 miles. Click to expand... tbh they shouldnt wear that badly.... Only time you re-shim is if you have to regrind valves - which at that point - a fraction off may actually bring you back INTO spec I'ev not touched mine - im at 85K Ziggy
Mike1alike Established member Joined Aug 3, 2017 Messages 810 Points 241 Location Timisoara Jan 28, 2025 #8 The correct clearances are: Inlet: 0.35 +/- 0.05 mm Exhaust: 0.45 +/- 0.05 mm Attachments Fiat Punto 1.2 8V Tehnical Data - From 06-2003.jpg 144.7 KB · Views: 18 Fiat Punto 1.2 8V Tehnical Data - Up To 06-2003.jpg 110.4 KB · Views: 21
