Ok so I need to replace the clutch on a 2011 Fiat 500 0.9 Twin Air. Any tips much appreciated.
I've done a few clutches, but never on a fiat and I can't see how to remove the half shafts from the gearbox . Some threads talk of removing the wheel lower link from the wishbone and tie rod pin so you can swing the wheel out the way and remove the shaft from the wheel bearing. Then just pull the shaft from the gearbox?
How is it held in and how much force to remove it - will i need a sliding hammer?
One of the half shafts has a plate a plate with 4 bolts do i remove this?
I presume the gearbox oil will need to be drained - what spec oil is used. Also is it just fill to the fill plug level?
Thanks in anticipation,
The fist pic is the shaft with the plate, the second pic the other shaft and the last is the gearbox - with i presume the drain and fill plugs.
