Greenwoodvehicleservices
- Nov 11, 2018
- 6
- 3
Hi all. This is my first post on any forum but figured this may help some with this fault if having difficulty. This is on a grande punto 1.4 petrol 2006
Before I start be very careful using a multimeter around any airbag wiring!
Went out to vehicle and code b0117 front crash sensor showing. Permanent fault that cannot be erased. Having rang fiat and finding out the cost of a crash sensor and almost dying I decided to carry out some further checks.
Behind the front grill towards left hand side is where the crash sensor is located. To gain access you must remove some torx 30 and gently pull away the plastic piece. The sensor is then held in place with a 10mm bolt. Remove the bolt and lift the sensor and wiring up. I then disconnected the battery. If you look under the fuse box on the nearside there will be two multiplug connectors. The one on the right, the black one is where the wiring goes to from the crash sensor. Disconnected that and the one to the fuse box above it. That is the two connections from the front wiring loom. I also disconnected the crash sensor.
This is where the multimeter comes in so be 100% nothing else is connected to either the fuse box or control units. All that is being tested is the wires. Nothing else connected.
On the wiring the crash sensor wires are coloured black and brown and then the other is red and green. I tested continuity between the multiplug near fuse box and the wiring at the crash sensor. Tested black and brown first. All okay then tested the red and green. No continuity. Started testing wiring moving leads closer from multiplug to crash sensor plug until it had continuity. Eventually it did indicating a broken wire. In my case it was rotten. Just green dust was all the was left. Stripped wiring back and soldered. I used a gas soldering iron not a mains one. Rebuild everything and check codes erased. All went out. Hopefully this help someone. I am new to this forum stuff but don't assume it's a crash sensor as they are not cheap new!!!
