1.3 multi jet
Very reluctant to start from cold, can take several cycle before it picks up. Up to 40 seconds before it picks up.
Just as if the glow plugs were not working.
Glow plugs replaced by garage (all 4) no difference
Once started, runs perfectly.
Fuel filter replaced. No difference.
Egr valve replaced. No difference ( original refitted )
Battery checked , very healthy, correct type and only 2 years old (stop start type)
Basically once started, runs ok, stop any time during journey, no problems starting at all. (first turn)
Stop and park, go back after an hour ( engine still warm ) it will then take a shorter while to start maybe 10 seconds, but defiantly not straight away.
It's almost like the fuel is drawing away from the fuel rail and needs to reprime every time, however no major priming sounds from the pump?
Any suggestions most appreciated.
Car still in the garage ( non fiat but got the software and they have always been good in the past ) but they are starting to scratch their heads...now thinking injectors?
Ken
Ken
