cheapomulti
- Aug 11, 2008
- 82
- 21
Hi there I'm having problems using my new Vag-com/KKL interface and my multipla 1.6
Every time I try to use it with multiecuscan I get latency out of tolerance warnings and it will not connect to the car.
I have tried dropping the port latency in the advanced port properties on the laptop (old dell d430 winxp 1.3ghz ulv dual core with 2gb ram and ssd drive) which lowers the latency enough to allow me to connect to the ecu but I still get a latency high warning when multiecuscan is running and it occasionally drops connection.
I should add here I've tried it with my D620 (2 Ghz dual core 3gb ram 500gb hdd also winxp) and get the same problems.
Multiecuscan connects to the Ecu just fine with my ELM327 but as you know you need the kkl to access the abs and airbags with the coloured cables.
Do you think this could be a interface fault or a bad driver... Are there any other drivers to use for the kkl cable.
thanks for any pointers you can give .
