Old 25-01-2012   #1
Rear brake MOT failure
Hi, i hav a 96' mk1 1.1 punto, it just failed its MOT on both rear brakes, iv not had time to look at it yet so thought id ask for advice that might help when i come to it. Do the rear wheel-cylinders seize on these cars? Will it have a load-sensing valve? Any advice would help, thanks.
Seany84 is offline Reply With Quote Quote
Old 25-01-2012   #2
Re: Rear brake MOT failure
Rear wheel cylinders for most cars are pretty cheap so seized or not doesn't really matter at this stage
The important thing it to establish if there is any material left on the shoes my guess would be probably not
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers can’t be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is online now Reply With Quote Quote
Old 25-01-2012   #3
Thanks mate, i'll give the drum and the linings a good key while im at it anyway
Old 25-01-2012   #4
Trader Rating: 10
dave has donated!
did it pass hand brake test or fail on both?
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 26-01-2012   #5
It failed on both i think but the handbrake feels ok to me.
Old 26-01-2012   #6
Trader Rating: 10
dave has donated!
i'd remove drums check meat on shoes, if ok remove clean and refit, check auto adjust is working, if not adjust by hand. if not ok fit new shoes and cylinders at the same time, it a real pisser if a cylinder starts leaking after fitting new shoes, you have to chuck them away and start again.
Old 30-01-2012   #7
Cheers mate. I had a look at the brakes at the weekend, both cylinders were seized, the drums and linings were good, i fit new cylinders, bled 1, good brake now on that wheel...however, upon doing the other 1, passenger side, i couldnt get any pressure what so ever on the pedal to bleed it! The pot is full of fluid and not dropping upon pressing the pedal, i think its obviously a master-cylinder problem, the seals i presume, some1 has told me to back-bleed it saying it will push the seals back, has any1 tried this?
Old 30-01-2012   #8
Trader Rating: 5
fingers99 has donated!
Can't see it working. The seals are either good or not (black fluid indicates they're certainly not). Master cylinders are cheap.
M12 fund £20
fingers99 is offline Reply With Quote Quote
(T) MOT Failure: Brake drum locking device insecure [3.5.1k]?? GizmOwin Cinquecento / Seicento 3 08-02-2010 17:00
(G) Brake Pressure Regulator: MOT Failure chr1s Ulysse 14 16-08-2009 21:31
(T) Rear Suspension Mot failure daniels87 Punto (Mk2/2b) 5 06-04-2009 20:22
(G) MOT failure, brake binding and headlights too high? jammydodger87 Cinquecento / Seicento 4 30-04-2008 18:03
(T) rear caliper MOT failure Gun_Metal_Grey Uno 9 27-04-2006 12:10
