are re profiled cams worth the money? can you get the same gains as a new set
ps never use piper cams
:bang:
In my opinion... the cam profile changes on their own would deliver little, engine mods of that type need to be done in conjunction with others so they work together. The risk is that you end up making the engine great for racing but not great for road use.
already got a single box exhaustBlueprinted...But cams are the only real tuning move, the head refacing could be classed as a slight compression rise I guess. Really on top of all you have had / are having done you need to stuff more air in there, add some extra fuel & get it out of the cylinders faster, kind of does that having the porting done, but a big valve head & a straight through exhaust would help (but probably get you pulled by Plod every day)
i thought that but lee said he should still be able to drill itbut your inlet manifold is plastic
big valve head
sounds expensive! ill have a word with the guy doing the work thoModified cylinder head with bigger valves....
ps never use piper cams:bang:
Basically not possible with 16v FIRE head. Have you ever looked at one? There are very few ways of increasing efficiency of this head. Very little redundant material.Modified cylinder head with bigger valves....
Nonsense!
funny how iv been told by loads of people that they got ****ed around by them aswell! bunch of :tosser:
Cams are on the way back got half a mm more lift and 10 degrees more duration
Paid for and got um nowspoke to some one tonight and they said you will never get it to run right with a reground cam as you wont know where the flats are because of the way the cam carrier is all closed in, you have to buy them new
