Technical  Urgent Help error codes
Hi Can anybody tell me what these 2 error codes are
P1684,P1687
would really appreciate any help with this.
Sorry forgot to add I've got a 1.6 16v 02 plate 5 dorr Stilo
Hello,
P 1684 is a fault during self learning of throttled body (low battery or plausibility)
P 1687 is an interruption of throttled body self learning for incorrect
environmental parameters (plausibility)
these are the official Fiat technical fault descriptions.
so it seems you have a problem with your throttle body.
yellowstilo
Sounds as if he needs the ECU and throttle body updates or if he's lucky just the ecu butterfly flap cleaned :chin:
Charlieboy - sounds like you've a similar issue to me following my cars recent battery change - see thread :
https://www.fiatforum.com/stilo-technical/97556-battery-change-now-engine-fault-no-revs.html
I'll check to see if the error codes match mine but my issue is with idle everytime I come to a halt and appears to be something to do with the ECU to Throttle Body config? FIAT Dealer has had to car - performed resets but theres one more to try which is the Throttle Body reset on Tuesday - Will let you know.........
