- Sep 12, 2003
- 46,073
- 7,134
Funny you should say that, that was the exact reason to start using mine, after I broke my right hand last yearCan't say I ever use mine but very handy if you ever break your hand
extreme self abuse
.....has Stu has just clouted custard around the ears with his good hand then?Well you live and learn :devil:
could this help the judder problem? if its supplying more revs at low speed?
Something wrong with your motor if it can't use standard fueli know what you mean by Judder mine did this until i stopped using BP and changed to Shell it runs great now, and i thought it was my driving!!
True Alex - but it does allow you to feel the road a tad better.Anyway I see no advantage in the steering being artificially 'heavy'. It doesn't help the wheels grip the road any better.
I leave the 'City' button on all the time. I think it's a terrible shame that people out there are avoiding the use of such features so as not to wear them out...
-Alex
I prefer mine without dentsAgree, You dont need to feel the road through the steering, you feel it in the seat of your pants if its starting to slide, I leave it on all the time.
It will switch its self off at speed its only for parking
if I'm doing something bad I can change my bad habits or just carry on driving without worrying. LOL
Mine does not switch off at speed either.It will switch its self off at speed its only for parking..after some failures with the duel logic power steering in the panda section I'm beginning to see a pattern developing ..use it and the unit is failing and don't use it and the unit doesn't and for that reason I don't use it..not that its even needed on the new panda cos the car is sooooo light anyway..
It doesn't switch off as such but the assistance is disabled at speed (anything over 40 I believe) and as you say it removes what precious little road feel the Stilo provides. It also increases the load on the front wheels (if you hit a kerb) whilst parking so, rather ironically, that's another reason I don't use it.Mine does not switch off at speed either.
Is that a feature they added later to stop the motor burning out from being used all the time.
In the past I have heard about it failing if it is over used, it could be only on heavy cars like the JTD or Abarth though.
Myself: I never use it as steering is very light anyway.
However, I'm led to believe it improves the slow running characteristic of the engine (for city driving) so that might be a reason to try it :chin:
