FIAT Auto Specialist Team
Old 28-02-2007   #1
Driver Extraordinaire
minimad99 has donated!
Beep Beep - water in fuel filter
Just had 84k service last friday and took car out today for a run. 6-7times got warning message, "water in fuel filter". over a approx 80 miles period.
I definately paid for the new filter and it certainly looks like a new one. i've called dealer and they think maybe switch has gone.
i should add that the car was displaying this message before the service too buy assumed was genuine and left it as service soon. seems to come up when going up or down hill but not everytime
dealer charging - switch £15 plus vat plus 0.25 labour, total about £35
Anyone heard of anything similar and also how hard to change these switches? would it be the one on the bottom or the one at the top on a black plastic collar type thing?
cheers
minimad99 is offline Reply With Quote Quote
Old 28-02-2007   #2
Re: Beep Beep - water in fuel filter
update;
well checked elearn which shows it's the switch on the bottom of fuel filter.
Removed the filter and cleaned up the switch with WD40. Also drained the filter a bit in case there was water inside.
After 40 mile drive no BEEPS, hooray, hope it's fixed
Old 01-03-2007   #3
The WIF sensor is simply a switch which sits in the fuel / water separator and activates when the water level gets to a certain height in the housing. Is it an electrical resistance type?? I don't know with Fiats.
Normally the housing should have a little drained out the bottom every so often to remove this water. I used to drain about half a cup out every year in my old diesel cars. That was enough to ensure all the water was removed, and some diesel too.
Water in diesel fuel system is very bad for it. Hence the separator.
Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS.
2004 1.8 Vauxhall Vectra - 5 Door
1974 3.5 V8 Triumph Stag - 2 Door
Stilo_ste is offline Reply With Quote Quote
Old 01-03-2007   #4
Years ago , new to Diesels, I was asking advice at a main dealer ( long closed) about changing the fuel filter, whether it needed to be refilled with fuel or would self prime.
The tech who had kindly come to talk to me, said " I just pour the old into the new".
Decent to be offered advice of course, but I have been changing my own fuel filters ever since.
oilrag is offline Reply With Quote Quote
Old 01-03-2007   #5
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Quote Originally Posted by Stilo_ste View Post
It sounds like you're saying you shouldn't need to have the filter changed at all (unless due) if you get this message?
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 01-03-2007   #6
In my last car (diesel), I covered over 80K miles, and only changed the fuel filter once !
I did drain it every so often though to remove water. WIF and filtration is different.
All diesels should have a drain for water in the separator, and if they don't - maybe they should IMO.
The 'water in fuel' message is NOT filtration dependant, but the WIF sensor has been activated.
To answer Argo's question directly, yes I am saying the filter does not NEED to be changed if you get the message, unless it is due to be done anyway.
NEVER pour old contents into new or leave in the housing. Always remove the contents. Does Stilo have a pump prime device? Either a rubber bulb or plunger????
Old 02-03-2007   #7
don't know but try not to use cheap supermarket fuel cause it is c**p
lalli is offline Reply With Quote Quote
Old 05-03-2012   #8
Macedonia
Quote Originally Posted by minimad99 View Post
update;
Helo Minimad i saw your post i was looking for help and i think your problem is same as mine.I see this post is old but if you read it please give me advice what to do.
I have stilo 1.9 jtd 2002 and have the light in dashboard "water in fuel filter" i replaced today with brand new fuel filter, but i still get the message in my dashboard what could it be please help me. sorry for my bad english have good day
Noli is offline Reply With Quote Quote
Old 05-03-2012   #9
My other cars a tractor
pieandapint's Avatar
pieandapint has donated!
Quote Originally Posted by Noli View Post
I had this last week after driving through lots of heavy rain and water on a several hour motorway journey south (don't know if it's related?).
Anyway, I drained the fuel filter but the message continued (I thought perhaps it takes a few clear starts to remove the error but it persisted!)
I again drained the fuel filter and completely unscrewed the sensor and while keeping my finger over the hole on the bottom of the filter (so I didn't lose gallons of diesel) I sprayed both the electrical plug and socket with electrical contact cleaner and I gave the metal part of the sensor a blast too. I haven't seen the message since.
Hope this is of help.
Dave
pieandapint is offline Reply With Quote Quote
Old 06-03-2012   #10
Macedonia
Quote Originally Posted by pieandapint View Post
Dave
Helo Dave
Thank you for your advice i will try that now but please can you confirm to me if i can spray with WD40 or is there any other spray that should i use.
Have a good day
Old 07-03-2012   #11
Helo Dave
Have a good day
I used a spray can of "electrical contact cleaner" mainly because I set out to clean the electrical contacts of the sensor as a lot of error messages on the Stilos seems to come from resistance in the wiring!
This is what I used: Electrical Contact Cleaner
Quote Quote:
The Halfords Electrical Contact Cleaner is ideal for cleaning ignition components and other precision parts. It removes tarnish, dirt, grease, dust, oil and other deposits, preventing arcing between dry contacts.
Regards
Dave
(G) Fuel filter heater GAC Marea 0 04-12-2006 17:40
(T) No Fuel Filter? HardBoiledEgg Punto (Mk2/2b) 1 27-03-2006 22:35
(T) Punto 75sx Fuel Filter Leak Wallis_Online Punto (Mk1) 0 27-03-2006 12:09
(T) modifying fuel and air intake lines shnowzy Cinquecento / Seicento 0 04-06-2004 06:06
(T) Water in fuel light Tapbuster Punto (Mk2/2b) 2 21-12-2003 23:25
