I am looking for the F60 fuse (if I remember correctly the nr)
It should be the one controlling the driver's electrical seat: I have a very unusual malfunction within the side mirror linked to this seat.
Basically if you have electrical seats with memories you have a peculiar "Parking position" for the passenger-side mirror which automatically goes into the stored Parking position when you select reverse gear (only if you have Confort Pack).
When you then release the reverse gear into neutral or any other gear the mirror goes back to his normal stored M1,2,3 position. This has always worked perfectly until a few days ago.
This function is now partially not working as the mirror does not go back to the normal position after reversing and I am pretty sure is the fuse, I just could not find it.
The same fuse should control the seat and the mirror with Parking function as this is memorised in the seat M1, M2 and M3 (3 positions for seats, mirrors and Parking function).
I am confident it is the fuse as the car has not been used for a while and it has been very wet recently so it might just be a quick reset that is needed (taking out the fuse for a few secs sometimes does the trick, eg. electrical windows fuses).
All the other functions of this mirror are perfectly working instead.
Any other suggestion would be greatly appreciated.
Thanks.
