Old 13-07-2006   #1
OBD Socket
Hi
Anyone got the OBD2 socket pinout information / colour codes of wiring to OBD socket.
Tim T is offline Reply With Quote Quote
Old 14-07-2006   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Re: OBD Socket
What do you have in mind? There are no wires to the EOBD socket as it's part of the body computer. Most of us are just happy to find a compatible plug and software and plug into it without worrying about what colour wires or what pin does what
So what's your plan?
Taken from Dte so i take no responsibility for its accuracy
Pin 16 power in
4 and 5 earth
Pin 1 ABS
pin 3 airbag
pin 7 engine management
9 steering
13 tyre inflation
12 cruise control
6 and 14 B can network
models probably vary a little depending on accessories and options
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 18-07-2006   #3
Re: OBD Socket
Initally Hack into K Lines(C Can) and start listening to comms signals and progress from there. Yellowstilo has done this whilst examiner connected and read comms signals thus able to reset service light without examiner using CAN USB sending service reset signal.
What Software are you using on B Can and have you link to download it.
Old 18-07-2006   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: OBD Socket
Be careful...trying to reset the service light using incorrect equipment often resets the whole cluster including the mileage.
Old 19-07-2006   #5
yellowstilo has donated!
Netherlands
Re: OBD Socket
Resetting service is a matter of sending the right command the right way - it can be done with the can-hacker hard- and software so without the Examiner. If done the right way it doesn't reset the whole cluster, just the "service due " warning .
Tim, you mention K- lines and C-can as one item - K-lines are for diagnosing C-can nodes with their own protocol (KWP2000 for engine node) on the Stilo- communication on C-can is used for exchanging information to other nodes , not for diagnosis!
In the near future C-can will be used for obd-diagnosis on C-CAN on newer Fiat models.
See my other posts searching for "service reset" .
Yellowstilo
yellowstilo is offline Reply With Quote Quote
Old 19-07-2006   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: OBD Socket
Quote Originally Posted by yellowstilo
I'm not saying it cannot be done(I said 'be careful') but I have had 3 recent 'attempts' that have gone wrong,much to the customers expense!
(G) Does a 2001 Brava have an OBD Socket? ciddy Bravo / Brava 8 14-06-2006 09:27
(T) power socket in boot ProtoFJ Stilo 3 11-08-2005 09:58
(T) Using the boot power socket for an amp?? Stemondo Stilo 0 06-04-2005 13:59
(T) Marea 20v, water in spark socket elkur Marea 12 24-08-2004 08:05
