DubWitStilo
Yep its COOL
Reason I ask is that I'm thinking of doing this soon as Kwik Fit are currently doing Aircon Recharges for £25
Dave
If your aircons still sound but lost pressure
Kwik Fit now put it on one of the auto machines
to purge and refill for £45.00
John
Suspect the flexible pipe, oil ring, or condensor
then. If your thinking of doing it yourself then
NEVER test a 134a system with compressed air
IT EXPLODES with R134a under pressure.
If your previous charge has a leak detector fluid
in it you can check the pipes and unions with a UV
light. It's also illegal to vent R134a to atmosphere unless
it's leaked from the system.
Check yellow pages for aircon repairs then ask around
to see if they are ok blokes. They can test for leaks
you have a choice then let them repair or if you feel
capable repair it yourself, if there is no pressure at
all in the system then you will need to look at the
reciever dryer and see if that needs replacing too.
John
So the good news is that my air con no longer leaks. The bad news is that it POURS! I left it since i last posted here and the cracked pipe has now become a broken pipe. I only realised when i bought a can of air con sealant, i put it in and then i realised there was no pipe attached and the sealant went straight out.
You can see where its supposed to be attached. My bro is suggesting a DIY fix whereby we cut off the ends and attach this and that to it and put it together and hold it in place with jubilee clips... Is it easier to get a new pipe and if so, how easy would it be to change it?
