Hi i was looking at the secret menu on the connect nav system (i.e when you press setup then click the connect selection 4 times then enter to get it up)
Well it has as the third selection (after "test speakers" and "next menu") block GPS for Netherlands and I selected that by mistake due to menu selection lagging and thought it was on the second selection (Next Menu) Duh!!!
My question is how do i reverse that what I have done because you cannot now go to that selection anymore as it is blocked, I thought it would have changed to unblock GPS but no it has stayed the same and you now can't select it, and the last item on the info list on that page for GPS block in netherlands is red and says "on" where it should obvioulsy be green and say "off"
If any of you can help that would be great
Sorry for the long explanation but wanted to make sure you know exactly what the problem is.
