- Aug 14, 2011
- 258
- 80
Hi folks
Looking for some help with part numbers for 6 speed gearbox for 2004 Stilo 1.4 16v.
The gb that is currently in the car is very noisy, although seems to function ok, but the garage suggests that it should be replaced before it gets worse/ fails.
The gb fitted is marked with the following numbers - 55181588 st3047B06 and C.101. I do have another gb for a 1.4 16v Stilo which I got second hand last year and put into another Stilo (again 1.4 16v car, 2005 year, also had strange noises which seemingly indicated impending gb failure - there's previous posts on here about all of that) which had some sort of catastrophic electrical failure before I ever got that car back on the ground and was able to run it, although the gb did physically fit with no real problems. Numbers on that box, however, are different - C513.514.44 and 73502791.1
The idea would be to replace the former with the latter, but now not 100% sure that it is the correct box based on the part etc numbers. Done a bit of searching on here and in the web, but getting ever more confused. Grateful for any expertise anyone has on this.
Cheers.
Cheers.
