Hello to everybody,
does anyone know what voltage should be on the crank sensor between the terminals?
Fiat stilo 1.6 16v, occasionally does not start and I measured 2V what go from ECU to sensor but I think it's little
Is the crank sensor the one visible under the crank pulley right next to the wheel arch? Where did you measure it? I'm half remembering a connector about head gasket level on the front of the engine?
