Got code 202 come up which keeps turning the engine warning light on.
says its injector 2 open circuit. I have changed the injector on 2 which i assume is counted 1-4 starting on the left if your looking into the engine bay from in front of the car and this has had no effect, the fault still happens on hard acceleration where the engine miss fires and then the light comes on. back off and the car still runs fine with the light on. Try and drive hard and it doesnt like it so would suggest still an injector problem. Any ideas please?. Is there a common bit of wiring that throws up problems may be getting too hot by the injectors?
