Hi diesel smell inside car, fuel pump leaking from somewhere botom, did any one have same problem? How difficult is to remove/change fuel pump. Timing belt for me not problem. LEAKING ONLY THEN COLD. Not much but still..
I've never removed a JTD high pressure fuel pump with the engine in place. I suspect the main problem will be access to get it out from the back of the engine.
You'll need to remove the pulley from the pump. It's on a taper fit, so you'll need to buy or fabricate a puller to remove it.
I'm not sure what it's like on the earlier JTDs (115s etc) and it may well be different but on the later variants (CF4, 150/170s) there was no way of getting the HPFP out with the manifold in place.
