Old 21-10-2012   #1
stilo 1.6 engine cuts out in low speed traffic- help!
Hi. I was hoping someone could help me as I know nothing about cars. My 2002 stilo 1.6 has a problem where the engine cuts out in traffic. This only seems to happen when I've been in low speed traffic for a while. Can be when I'm slowing to a halt or when I'm stationary, but the battery and engine icons light up on the dash and then it cuts out. My mechanic thought it was a hole in the exhaust causing the fuel readings to go weird, but welding that hasn't fixed it. He has also cleaned the butterfly but that hasn't done it.
From reading another post, it sounds like it might be electrical. Maybe the ecu? If it is that, is it likely to be a big/expensive fix? If it isn't that, does anyone have any other ideas? I just don't want to go to a mechanic and throw lots of money at it to try and find the problem.
I'm a bit on edge about the problem as I don't want it to happen halfway up a hill or somehing! So thanks in advance for your help. (And please bear in mind how little I know about cars!). Thanks
stilo22 is offline Reply With Quote Quote
Old 26-10-2012   #2
Re: stilo 1.6 engine cuts out in low speed traffic- help!
Hi Stilo owner with strikingly similar name.
I also had a strikingly similar problem with my JTD. It would cut out at low speeds, mainly in traffic.
It eventually cut out on the motorway and wouldn't start again. It got towed to a garage and they diagnosed the problem as a faulty 'cam position sensor'. It cost me £120 at the garage in 2009. However, it is easy to change yourself and the part shouldn't be too much.
Good luck
2003 Stilo JTD 115 5 door.
1985 Ford Fiesta 1100.
(The Wifes) BMW MINI Cooper.
JTDStilo222 is offline Reply With Quote Quote
Old 28-10-2012   #3
Quote Originally Posted by stilo22 View Post
after cleaning the TB you need to do a relearn... start with the easy stuff first...
procedure is in my sig
Rich
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks.
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust.
richydraper is offline Reply With Quote Quote
(G) cuts out when im stuck in traffic richardallen930 Scudo 4 24-03-2013 22:48
(T) stilo estate undriveable low speed vibration figaro Stilo 11 13-08-2012 16:20
(T) 2003 1.9d cuts out at low RPM when warm - help! scotster Doblo 1 30-09-2011 17:01
(T) Fiat Stilo 1.6 engine cuts out Terham Stilo 5 19-10-2009 13:16
