Stilo007
I have recently posted on here about my sat nav+ unit I bought. I was having problems getting the master code.
I was told to disconnect the canbus lines, and after many PM's and emails this did not work. I eventually took it to a Fiat dealer who put the car on the examiner to see if they could help.
THE TRUTH IS THAT YOU CAN NOT FIT A SAT NAV+ UNIT WHICH AS NOT COME AS STANDARD IN THE VEHILCE WHEN BOUGHT. THERE IS NO OTHER POSSIBLE WAY TO MAKE IT TALK TO THE ECU. IT IS THE ECU WHICH ASK'S FOR THE CODE NOT THE SAT NAV UNIT AND THERE IS NO WAY OF RESETTING THE ECU.
You can still use all the sat nav features its just that it wont display any information from the ECU.
IF YOU EVER BUY A SECOND HAND SAT NAV UNIT MAKE SURE IT COMES WITH THE ECU FROM THE CAR IT WAS TAKEN FROM.
