I have a 2002 Fiat Stilo 1.6 Active and after about a week of owning it I started to have the problem where the car cuts outs and displays ASR fault, Loose connection. Sometimes that error is shown together with an 'Alternator' fault. The car also has the Airbag error. I have noticed that the ASR fault normally occurs when the fuel level is low (just under 1/4 tank).
I have read the forums and have gone through most of the recommended fixes. I'm mainly concerned about the ASR fault as it is VERY annoying and dangerous. I understand that it could be caused by;
- a faulty Brake Light Switch (I have fitted a new one)
- a bad earth connection (I have disconnected and cleaned the C15 body computer connection and the D4 using electrical contact cleaner)
however none of these has resolved the issue.
It does look like the battery isn't the best but before starting to fork out money I wanted to ask if there is a cheap way of finding out if the ECU is fried. I want to buy a new battery but would be loath to buy one and find out that it didn't make a difference and still have to sell the car.
Any help would be appreciated. Thanks.
