ashharris1992
- Dec 12, 2011
- 10
- 1
Hey Guys,
Well cars and me don't go that well together so maybe you can give me some advice.
Went in to have my exhaust changed for the second time this year (under warranty from the exhaust centre I may add) and he pointed out to me that the rubber inside the mount on the bottom of the engine (above the exhaust) is pretty worn out and as a result is not giving as much resistance as it should; apparently this is probably why the exhaust has gone so quickly.
So I popped to my normal mechanic and he was too busy to look at it but the receptionist said she would text me a quote.
The exhaust centre made it out to be a very easy job and said it was just a matter of jacking up the engine - undoing the bolt - sliding the one out and sliding the new one it. 30 mins work max he said.
Anyway get the quote and im shocked that its in excess of £180.
Can I have some advice on this pls =)
Thank you
Thank you
