Shminkypinky
Member
My Stilo 1.6 16V Dynamic with 89,000 miles on it decided to throw a wobbler on Sunday.
The car lost power and started to run like it does whn a coil fails as if it is running on 3 cylinders.
Called AA who read code as cylinder 1 problem. He replaced the coil (I carry spares) then all the spark plugs.
Still the car ran as described - he was scratching his head at this point.
He confirmed all the signals were getting to coils and determined that the car needed a compression test.
Car had compression test by independant mechanic who reports that Cylinder 1 has no compression, cylinder 2 has 12.5 bar, Cylinder 3 and 4 have 19 Bar.
Any ideas?? Could this be as simple as a head gasket failure? hence the drop on cylinder 2 or am I likely to have furhet problems?? If so what could they be and what are the likely costs?
I am wondering if its worth fixing as the car is an 02 plate with nearly 90,000 on the clock. I will be gutted if its the end as its been a great car!
Mechanic will start to look at car later this week and says he will strip it down but until then is unsure of the problem. May be a head gasket, valve or more serioulsy a piston.
Any advice welcome.
Any advice welcome.
