I converted my abarth to LPG about 1500 miles ago. Everything was fine during the first 700 miles on LPG, but since then the engine struggles a bit to start after ~15 hours of rest. If I give him two days rest (weekends), it will not start on first try. Only on second try.
To make things worse, its drinking a little bit of water. I can see the water level drop about 2 millimetres every 190 miles.
Oil consumption is also up but I have a crankshaft seal leak and change from selenia to mobil at the same time as the LPG conversion.
I guess this means my gasket is failing, BUT:
- I cant see oil or any sort of stains on the water reservoir.
- I cant see water bubbles/Stains on oil Dipstick
- Car doesn't overheat.
- No white smoke. Just the regular smoke.
- engine Performance is very good
I hope the problem is with the LPG vaporizer somehow. If its the gasket I'm doomed €€
