I have had some problems with my JTD 1.9 (115hp). I keep getting error messages come up. I have replaced the battery and they are still happening. The latest is 'alternator failure*' and 'Loose connection' - *although this has only happened a couple of times. The car labours to turn over but fires up and then drives ok (and i can turn off the ignition and the fire it back up without any problem at all). Sometimes the steering warning light comes up and the power steering won't work unless i turn off the ignition and fire it up again, but once I do that it's fine again. Is it the alternator, starter or a poor connection on either?:bang:
The other problem I have been having is at about 3000 revs in fourth or fifth the engine warning light will come on and the msg 'engine failure' comes on and I am limited to no higher than 3000 revs (limp mode - I assume). This will stay for a while, sometimes a long while, and then go off allowing higher speeds (as long as I dont go over 3000 revs again. The strange thing is that it doesn't do it when I pull away in first and through the gears, only when im cruising and then accelerating - say on the motorway or dual carrigeway, overtaking or such like.
Any ideas? :idea:
Any ideas? :idea:
